1987 Jeep Wrangler electronic egnition
1987 JEEP WRANGLER
STEVERANKER
Electrical problem
1987 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
my nephewe brought his jeep over to get it started someone has tried to rewire it. I have power to the coil, but no spark. where do I locate the electronic ignition? Has new coil, new starter solinoid, turns over, and has fuel, but no spark.
Nov 4, 2009 at 4:16 PM
MIKEYREYNA1
  • 8 POSTS
its inside the fender under the master cylinder its an old ford type ignition module ( about a 5"x5" square aluminum )
Feb 4, 2012 at 11:51 PM
CJ MEDEVAC
  • CERTIFIED EXPERT
  • 11,004 POSTS
THIS IS WHAT IT LOOKS LIKE
http://www.autozone.com/autozone/parts/Duralast-Ignition-Control-Module/1987-Jeep-Wrangler-4WD/_/N-iibqeZ9n80t?itemIdentifier=118422_300759_0_
TO DISCONNECT IT, GRASP THE WIRES ON EITHER SIDE OF THE CONNECTORS AND PULL---DIGGING IN IT W/ A SCREWDRIVER, JUST BREAKS OFF THE LOCKING TABS....BESIDES, THE FACTORY MANUALS TELL YOU TO DO IT THE WAY I DESCRIBED
TEST IT 5-8 TIMES AT THE PARTS STORE---DO THE SAME IF YOU GET A NEW ONE, BEFORE YOU LEAVE.....DON'T ASK!!!
I DO CJs AND HAVE ANSWERED MOST OF 'EM FOR THE LAST 2+ YEARS....I MAY CAN HELP YOU TOO....MAYBE!
GIVE SOME BIG-TIME HISTORY, WHAT'S BEEN DONE/ MODIFIED---HAS IT RUN FOR YOU?....ANYTHING ELSE THAT MIGHT AID ME
DECENT PICS HELP TOO!
THE MEDIC
Feb 5, 2012 at 1:48 AM
