2004 Jeep TJ Welding precautions
2004 JEEP WRANGLER TJ
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
DENNIS JACKSON
Problem- I have a large nut-cert in a frame rail that has a bolt stuck in it. The nut-cert is turning in its hole. I would like to tack weld the edge of the nut -cert to the frame with 3-4 tack welds. The threads are recessed 1/4" into the nut-cert so I think i can tack it without disturbing the threads. I will disconnect the battery. Do I need to also disconnect the ecu. Does the ecu need power to it to keep its memory? The location of the nut-cert is midway between front and rear axels on bottom side of right frame rail.
Sep 3, 2009 at 6:07 AM
MMPRINCE4000
  • 8,548 POSTS
There is a device called "AntiZap" made by SPX-OTC that connects to battery on newer cars that protects the PCM and electronic components when welding.
You can also disconnect battery, PCM and Alternator.
Place MIG/TIG welding ground as close to weld target as possible.
The PCM will re-learn mormal operating parameters within a few hundred miles of normal driving.
Sep 4, 2009 at 12:13 AM
