2001 Jeep Cherokee Side Shake
JEEP
ROD1219
01' Jeep Chorekee (inline 6 , 4.0 58,350 miles) will shake from side to side at 30-50 MPH if you hit a small bump. I have to slow down 10 MPH to make it stop. I 've already changed the stablizer shock. What should I do next?
Apr 30, 2007 at 6:09 AM
MERLIN2021
  • 17,250 POSTS
I would check engine and tranny mounts...
May 1, 2007 at 7:54 AM
LOSTINMARS
  • 222 POSTS
jeep has a tsb on this. all the control arm bushings need to be changed in the front suspension. they have updated arms and bushings.
May 1, 2007 at 1:36 PM
MERLIN2021
  • 17,250 POSTS
hey lostinmars...is it a recall or just TSB?
May 2, 2007 at 6:24 AM
Suggested Repair
Inspect the engine and transmission mounts. Also replace the front control arm bushings, using the updated control arms and bushings referenced in the Jeep TSB.
Conversation Summary
A 2001 Jeep Cherokee with the 4.0 inline-six shakes from side to side at 30-50 mph after hitting a small bump, and slowing about 10 mph stops it. The stabilizer shock has already been replaced. Experts recommend checking the engine and transmission mounts and replacing all front control arm bushings with updated arms and bushings under a Jeep TSB. Whether the bulletin is a recall was not confirmed.
