2007 Other Jeep Models battery
2007 JEEP
30,000 MILES • 4 CYL • 2WD • AUTOMATIC
D-NEV
I have a jeep compass
the battery keeps getting corosion on the terminals
the positive terminal actualy coroded all the way apart.
I removed and replaced both terminals. Cleaned completly all parts and battery chamber. had battery checked at Kragen Auto ( good ). reinstalled with felt washers , dialectric greased both leads including nuts & bolts. It has been ten days.
This morning the car would not start. I checked the battery and the corosion has begun to return. I checked the leads and both were firmly attatched.
what is causing the corosion ? What should I check ?
Sep 14, 2009 at 11:32 AM
  • 31,937 POSTS
Hi there, check for an over charging alternator, excessive out gassing of the battery or even a small crack in the battery case or leaking cell cap, clean with a mixture of warm water and bi-carb soda, use an old tooth brush to get all the corrosion off, and coat with petroleum jelly or a good anti corrosion spray.
mark (mhpautos)
Sep 14, 2009 at 11:52 AM
