1999 Other Jeep Models oil burning??
1999 JEEP
125,000 MILES • V8 • AWD • AUTOMATIC
CHICKONBELAY
99 jeep grand cherokee limited AWD V8
has oil leak somewhere...burned through 4 quarts in 2 months...NO oil spots or fluids being left under jeep in driveway, not even a small amount anywhere (must be burning off completely)..can smell a small amount of oil burning off when getting out of car every once in a while. I have had jeep up on lift no visible sign of oil or leakage anywhere (under entire vehicle or under hood)...it's bone dry and clear of any visible oil. any idea where it could be leaking coming from??
Jan 27, 2010 at 3:47 PM
  • 75,988 POSTS
If its not leaking anywhere than its burning in the combustion chamber could be valve seals/stems/guides and cyl wear and rings-check engine compression to confirm-normally if its burning oil blue smoke should be existing from the exhaust pipe
Jan 27, 2010 at 9:04 PM
