1999 Other Jeep Models ENGINE MANAGEMENT/TRANSMISSION
1999 JEEP
JEMO102
Transmission problem
1999 Other Jeep Models Four Wheel Drive Automatic
Hi i have a 1999 grand cherokee wj with 62k miles
the engine management has came on and the transmission wont change above what feels like the secong cog, around 35 mph. it just goes into neutral/wont change up. when i slow it drops back to the second cog. i have just had to drive it home 200 miles at 50 mph on the manual 2 gear setting. everything else is working perfect.
any ideas?
cheers
Apr 4, 2010 at 7:42 PM
THIS IS MIKE
  • 686 POSTS
We appreciate your donation.
Check for any vacuum lines that may have become disconnected. Check for any blown fuses.
You will have to scan you computer for the exact trouble code. Pepboys and Autozone will scan you Jeep for free and report the codes back here using the reply to question button below. Make sure you are logged in before trying to reply.
Apr 7, 2010 at 11:08 AM
