1997 Other Jeep Models 1997 Jeep Grank Cherokee blowing fuse
1997 JEEP
305,000 MILES • 6 CYL • 4WD • AUTOMATIC
WOLVIE56X
my 1997 Jeep Grand Cherokee Limited has been blowing the same fuse for a week now, but it seems to only happen the the vehicle comes to a stop.
its the PCM fuse, which also has the automatic lights, instrument panel, radio amplifier and the vehicle body panel
i think there may be a few more on there, but its a really important fuse for the jeep, when it blows, the computer goes dead
we checked every open wire, the radio wires, the disconnected amp wires, the battery teminals and wires, checked to see if the fuse box was grounded properly, we are complete stumped right now
when the vehicle is moving, there are no problems, but when we come to a light or stop sign, it goes dead
and only that fuse is being blown
before this issue, we were never able to use the auto lights, they would just keep flickering instead of staying on and the interior lights could not be used, if turned on, they would go right out, but not blow the fuse
the vehicle shows no signs of any issues other then coming to a stop and the fuse blowing
Jul 31, 2009 at 12:53 PM
JDL
  • 16,098 POSTS
Hello, is it the 15 amp fuse that blows? The control side of fuel pump relay--asd relay--ac compressor relay are on that fuse circuit along with 3 or 4 other systems. I'd have to separate the circuits one at a time, try to see which one is blowing the fuse.
Aug 1, 2009 at 4:09 AM
WOLVIE56X
but the short story of it, CHECK THE DAMN O2 SENSORS THOROUGHLY!
ill list everything we did check and got no results, fuse #5 from the engine fuse box kept blowing, which houses the PCM/ASR
we followed the wiring harness ALL the way around and back to the computer, NOTHIJNG, no melting, no rubbing, no problems
we then took apart the engine fuse box and played around with the tightness of the area the fuses slipped in, nothing
got an error report, made it to Auto Zone and the computer was reading high voltage on the O2 sensor, but the guy was sure it was the front one, so spent $70 to replace that and still nothing
after about 6 hours of going through EVERYTHING, we gave up, sat in the jeep with my dad, he was flipping through the manual and the Jeep Haynes book and i was on my iPhone googling different wording and then we found it
the number ONE reason that fuse ever blows is from a malfunction with the either of the 2 O2 Sensors
so my dad crawled up under the middle of the Jeep and sure enough, the the wires for the O2 Sensor behind the catalayic convertor was dangling down and rubbing ont he axel
completely rubbed the rubber off the wiring and was making full contact on the axel
problem SOLVED
if anyone needs any info on what we did, i can post more
Aug 1, 2009 at 10:37 AM
