Hmm not much info in the question but ill try. You just said wipers are loose so i take it your talking about the wiper motor?? If its the arms or the blades those are easily replaced at autozone, just have one of the employees come look at it and he will get you what you need. Most likely its the studs the wiper arms mount to you are refering to. The two short grooved studs coming up from the body that the arms connect to. Depending on the vehicle there is a motor and a follow arm that runs the opposite wiper. Fist i need you to look at this while its in motion and see if you can tell where all the play is. DO NOT GET YOUR ARM or hand in the mechanism while its running it hurts like hell. SO BE CAREFUL. Do this and then get back to me. Thanks Curt
Dec 7, 2008 at 11:17 AM
