1990 Jeep Overheating Coolant Loss
1990 JEEP
GCT717
hello, i have to check my coolant every week, to see if all the coolant drained out. once,i do that, i fill the overflow with water or coolant. i use water becasue once i fill the overflow it drains into the radiator within the matter of seconds, then comes right out then i put more, that drains. when i'm done filling it up. i drive about 10blocks. once i turn off the car i hear this rumbling loud sound comimg from my overflow tank. i lift my hood up, then all the coolant comes from the top of the over flow. i know, that the overflow cap does not fit. could that be the problem? i changed my thermostsat, radiator,and fan, however; my a/c blows out warm air, and the a/c fan under the hood does not come on.sohuld i just get a whole new overflow tank? please help i'm tired of buying and putting coolant every week.
Jul 15, 2006 at 2:27 PM
MIKEYBDMAN
  • 623 POSTS
Ok, your radiator should not overheat even if you have no overflow tank at all.
Here are the simple facts of a cooling system. If you have to keep adding radiator fluid, you have a leak. You must find where the leak is, and fix it to correct your problem. So, my first question is, where is the radiator fluid going when it leaks out? Do you see where the leak is?
Ok, if you see the leak, repair or replace what ever is leaking, and that should solve your problem.
If you dont see any leak, then maybe the engine is overheating and when it does so, it forces the water back out of the overflow. If this is the case, your thermostat may be stuck closed, and needed to be replaced. This is a cheap and easy fix that might solve all of your problems.
If your thermostat is not the problem, and you cannot see an obvious leak, then it is probably one of two things. Either your radiator fan is not working properly (Should cool some while you are driving without the fan on), or you have a leakinternal of the engine and the coolant is either going into your engine oil, or being burned thru the cylinders. What happens is either the head gasket is leaking or the intake manifold is leaking. You can check the head gasket by running a compression check on your cylinders and see if any or too low.
Good luck, and hopefully it is just the thermostat.
Jul 16, 2006 at 7:33 AM
GCT717
the leak is coming form the overflow cap. all the coolant that i put in comes all out again. i had a theromstat, i took it out for about eight months, just replaced it.could it be my overflow tank cap that does not fit? i got a new radiator fan, and it blows great!
thanks!!!
Jul 17, 2006 at 3:48 PM
Suggested Repair
Do not rely on replacing only the overflow tank. Repeated coolant loss means a leak that must be found and repaired; install a correctly fitting cap if the current one does not seal. If coolant is still forced out after short drives despite the replaced thermostat, radiator, and working fan, check for an internal leak such as a head gasket or intake manifold, including a compression test.
Conversation Summary
The owner of a 1990 Jeep must add coolant weekly. After driving a short distance, coolant is forced out of the overflow, and the overflow cap does not fit. The thermostat, radiator, and radiator fan were replaced, but the A/C blows warm and its under-hood fan does not run. The expert says the absence of an overflow tank alone should not cause overheating and that the leak must be located and repaired. If no external leak explains the loss, possible causes include a thermostat or fan problem or an internal leak from a head gasket or intake manifold, which can be investigated with a compression test.
