Transmission problem
1961 Other Jeep Models 4 cyl Four Wheel Drive Manual ? miles
CJ3. Original transmission; don't know about clutch. Problem: We can't shift because gears grind. If the engine is not running, shifting is possible.
We can start the engine in neutral or in gear, just can't shift while engine is running.
The clutch pedal feels the same as always (same pressure, same 1.5 inches free play). This problem developed all at once while driving slowly in lo gear in a field.
Does a clutch plate go all at once? There was no noise to suggest anything was tearing apart.
Thanks for your suggestions. --Peter
Nov 15, 2009 at 1:28 AM
