2004 Jeep Liberty water pump
2004 JEEP LIBERTY
20,000 MILES • 6 CYL • 4WD • AUTOMATIC
HELENCANDELORO
This morning the water pump started leaking smoke coming out of the front end and I had to pull into nearest gas station.
Mechanic tells me the thermostat should be replaced as well and a hose that is soft should be replaced.
All in all close to $800.00.
Does this sound at all reasonable.
Mar 16, 2010 at 7:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
800 bucks just for replacing a radiator hose, thermostat and water pump on your vehicle is WAY overpriced. these repairs, including parts, should only be around $350 .. may want to have another shop give you an estimate on those repairs..
Mar 16, 2010 at 6:32 PM
