2004 Jeep Liberty Rear Passenger Side Light Assembly
62,000 MILES • 6 CYL • 4WD • AUTOMATIC
STANCATALDO
How do you remove lens cover to replace stop light? I found two torex screws and removed by lens cover didn't come off.
Feb 4, 2008 at 12:04 AM
JEEP03
  • 21 POSTS
The first time I tried to change a burned out bulb, I couldn't get the lens removed. I brought it to the dealer to do. After removing the torx screws, you have to be real aggressive an wiggle the lens back and forth while pulling. The tech at the dealer says all the libertys have this problem. When you finally get the lens out, lubricate the pins that insert in the holes, this should make it easier to come out next time. I thought the tech was going to break my lens when removing it, so you really have to go at it to get it out.
Feb 27, 2008 at 12:24 AM
