Thursday, June 19th, 2008 AT 6:03 PM
" check engine " light comes on after filling my gas tank. I turn it off by disconnecting the battery cables. The light will remain off until after I fill up again and I have to repeat the routine. ( I always remove the ignition key so that the ignition is totally off during filling ). Can you suggest a permanent fix?. Tnx. Matt
