air intake input circuit low
COOLCEE101
replaced sensor tried to reset but check engine light came backe on.code 112.2003 jeep laredo 100,000 miles v6 4x4
Jul 16, 2007 at 2:36 AM
MONKEY4421
  • 9 POSTS
Some "codes" are stored in the vehicles memory and can only be removed by equipment that can communicate, i.e., two-way communication, with the computer. If you are only "reading" codes, simply removing the negative battery terminal may not remove this code. Many codes that have to do with emissions are stored this way. I would suggest having someone with a scanner that can "tell" the computer to erase this code, do so, then rechecking.
The other cause of this problem could be a dirty intake port, especially if dirt carbon, or oil are laccumalating in the area around the sensor.
"Decarbonizing" the intake may help this also.
Jul 17, 2007 at 8:17 PM
