2000 Jeep Grand Cherokee AC Overheats
VITEZJZ
I have 2000 Jeep Grand Cheeroke Laredo with 106000 miles on it, and whenever i turn on A/C my engine overheats. Does anyone know what could be wrong with this? :?:
Aug 22, 2006 at 1:43 PM
MIKEYBDMAN
  • 623 POSTS
[quote:b7dbf7dfd7="VitezJZ"]I have 2000 Jeep Grand Cheeroke Laredo with 106000 miles on it, and whenever i turn on A/C my engine overheats. Does anyone know what could be wrong with this? :?:[/quote:b7dbf7dfd7]
Well, does your truck have a fan attached to the engine, or electrical fans mounted to the radiator? The reason it gets hotter with the AC on is it adds a load to the engine, and the condesor is used for cooling, which robs some of the air for the radiator. Usually if you have electric fans, they are commanded on when the A/C is on. If you have the fan attached to the front of the engine, it should lock up the clutch when the increased temp is sensed and turn faster. If this is not happening, you may need to replace the clutch for your fan.
Aug 23, 2006 at 1:07 PM
Suggested Repair
Confirm whether the Jeep has electric radiator fans or an engine-driven clutch fan. Electric fans should run when the A/C is on; a clutch fan should lock up as temperature rises. If the clutch does not engage, replace the fan clutch.
Conversation Summary
The owner of a 2000 Jeep Grand Cherokee Laredo with 106,000 miles says the engine overheats whenever the A/C is turned on. The expert explains that A/C adds engine load and the condenser reduces airflow to the radiator. Electric fans should come on with the A/C, while an engine-mounted fan clutch should lock up as temperature increases; a clutch that does not engage may need replacement.
