2003 Jeep Laredo Electrical Problems
74,500 MILES • 6 CYL • 2WD • AUTOMATIC
AXT0KTR
I have been having some elecrical problems with my Jeep. A week ago the radio went out and my dash lights and odometer started blinking. It went away for a few days and then just two days ago I went to get back in my car after just driving it an hour earlier and it would not crank and no lights would come on. I had to jump start it to get it going. I had the Battery checked and it came back as fully charged with no deffect. I don't know what could be wrong. please assist... Thank you
Feb 17, 2009 at 2:25 AM
JDL
  • 16,098 POSTS
Hello, I'm not sure of the litre size of your engine, 4.0?
Are the battery cables/wires in good shape on both ends, clean? There should be a starter relay in the power distribution center under the hood. You can unplug the relay, use a test lite, two of the terminals should be hot, with the key in the crank position. Any testing, make sure the tranny is in park or neutral. Let us know.
Feb 17, 2009 at 2:58 AM
AXT0KTR
the cables are clean and in good shape. I will try to test that relay switch and get back to you.
Feb 17, 2009 at 3:05 AM
