2002 Jeep Laredo SHUTTING OFF
207,000 MILES • V8 • 2WD • AUTOMATIC
CANDICEFK
Jeep shuts off when RPMs drop below 1000 at red lights/stop signs, unless I put it in neutral when coming to a stop. If I shift into neutral it will not die. CHECK ENGINE LIGHT IS NOT ON.
Aug 8, 2010 at 7:45 PM
  • 110,248 POSTS
Have you checked for vacuum leaks?
Aug 26, 2010 at 1:01 AM
CANDICEFK
Apparently no vacuum leaks, IAC has been cleaned, throttle position sensor and crankshaft sensor have been replaces along with a relay, and when hooked up to a diagnostic machine, computer throws no codes.
It seems to only do it now when it is midday and very hot outside, or if driven for a longer amount of time, like after 20 or so minutes. It is wierd, but it seems to run much better at night time.
Also, now when it does start acting up, I can have my foot off the gas and brake and the car will jump from 500RPM to 1500RPM quickly and actually jump forward. This doesn't happen everytime though. One other thing is every now and then the gas gauge will bottom out for a few minutes then go back to where it originally was.
Aug 26, 2010 at 6:36 AM
  • 110,248 POSTS
That is strange. But at night, everything is cooler. If there are no codes, then I would lean toward a vacuum leak or fuel issue. However, the RPM issue sounds like the IAC or TPS.
Aug 26, 2010 at 2:43 PM
