2001 Jeep Laredo Bluish greasy film on inside of windshield
2001 JEEP GRAND CHEROKEE LAREDO
12,000 MILES • 6 CYL • 4WD • AUTOMATIC
YANKEESTONK
For about 2 months I've had a recurring film on the inside of the windshield. It's greasy, looks like the window is just fogged up but it's more than that. It smears with your finger like it's greasy, but doesn't feel "wet". It's hard to clean off, and will return. Seems to come from the heater. Looks almost like a window of a heavy smoker, but I don't smoke. I believe it's comiing from the heater or AC. May be anti-freeze? I did have to add Anit-freeze twice this year to top off when light came on. Never had to do that before. But it will take months and months for the light to come back on. No leak on ground etc. haven't added A.F. in about 3 months or so. Any idea what it might be and what to try. I've never had the radiator flushed, should I try that?
Dec 14, 2009 at 11:08 AM
BEEF99
  • 152 POSTS
It may be that your heater core is starting to leak and the heater fan is depositing residue on the inside of your windshield. Have someone do a pressure test on the coolant system to check for leaks. Do you ever get any moisture on your passenger side floor by the dash? If so, it is definetly your heater core. Good luck!
Dec 14, 2009 at 11:32 AM
