1997 Jeep Laredo Fuel Filter
1997 JEEP GRAND CHEROKEE LAREDO
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
TKENNEY
I have a '97 Grand Cherokee Laredo. The other day I gunned after someone turned abruptly. After that I had a sputtering problem. It didn't shut off and still runs and starts fine but still has the problem. I thought it was the filter but reading some of these forums i was unlucky in finding out that this Jeep has no filter. It has a regulator attached to the pump. is this true? And is there another possibility that is easier and less time and cost consuming?
Sep 7, 2010 at 11:41 AM
JDL
  • 16,098 POSTS
Check for applicable trouble codes, if you haven't already? You should be able to get mil codes by cycling the ignition switch. Cycle the key, on--off, on--off, on, no crank. The mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes. A tune-up is a manitenance issue, has it been a long time?
Sep 8, 2010 at 6:45 AM
