1995 Jeep Laredo wipers and fuses
1995 JEEP GRAND CHEROKEE LAREDO
195,000 MILES • V8 • 4WD • AUTOMATIC
LAP216
my dilays on the wipers dont work but low and high do i dont have a fuse or relay marked wipers but i beleve that thay are all good anyway do you know whats the problum ?
Dec 2, 2009 at 4:41 PM
BEEF99
  • 152 POSTS
I do not remember exactly where it is located but I do know that it is more than likely your wiper relay that is the cause of your frustration unless you had a mouse or person in there making a mess of your wires. Get a chilton's manual ($15) at the local auto parts store and it should show you. Try looking either on the driver's side or passenger side for a black box that is 3-5inch square with a thin plug going into it. This will be by the kick panels or by your steering column. If you do not find one of these, then one of your relays under the hood may be the problem. If it was your wiper motor, nothing would work or all would work just like it was meant to. Good luck!
Dec 3, 2009 at 10:29 AM
LAP216
Dec 9, 2009 at 8:42 PM
