1989 Jeep Laredo
CSWIFT
  • 1989 JEEP GRAND CHEROKEE LAREDO
Transmission problem
1989 Jeep Laredo 4 cyl Four Wheel Drive Automatic
Transmission will not shift into high gears will stay only in low gear and has been replaced. Also power fuse has been checked and is okay. What could the problem be?
Thursday, October 8th, 2009 AT 5:56 PM
  • 109,885 POSTS
I will assume you checked the trans fluid and it is full. There could be a couple problems. First, it could be a shift solenoid or the trans module. Has the check engine light come on?
Monday, November 9th, 2009 AT 10:20 AM
