1981 Jeep CJ7 no brakes
1981 JEEP CJ7
122,000 MILES • 6 CYL • 4WD • MANUAL
JCHEDLEY
I have replaced pads, calipers,brake hoses, shoes, drums, wheel cyl, and hardwarew on the back brakes. I have blead brakes all kinds of combinations and also have went through 3 master cyl and a power brake booster. I have bench blead master cyl each time before installing on vehicle.
I hit pedal first time and it goes to floor, it will pump up after about six pumps. I have gone thru 10 quarts of dot 3&4. I can't seem to get the brakes to work properly, any suggestions please. Thank you in advance, Jim
Mar 19, 2009 at 12:13 PM
  • 110,240 POSTS
Is the push rod that goes to the rear of the master cylender adjustable? also, when you pump them and get a pedal, will it hold or does it still go to the floor after some time? Also, when bleeding, start at the wheel the furthest from the master cylender (R rear) and work to the next closest and so on. It should be RR, LF, RF, LF.
Mar 19, 2009 at 1:56 PM
JCHEDLEY
I checked to see how far the stem pushes and it travels enough, it's not adjustable, When I pump the pedal, It will come up and hold untill you let it go. I have bleed the brakes like you suggested plenty of times and for the most ,I don't see any air most of the time. This Jeep came to me with the same problem, inadequate brakes, the rear drums were turned to much by someone and shoes were about 50% I replaced everything incl hardware on the rear. Thz for your help, what are symptoms of a bad P-valve? Jim
Mar 19, 2009 at 2:19 PM
  • 110,240 POSTS
The P-valve limits the amount of pressure goes to the rear brakes. The proportioning valve only lets a certain portion of the pressure through to the rear wheels so that the front wheels apply more braking force. If it is bad, you may find that the rear brakes would lock up easier. It could also have an effect on the pedal. However they rarely go bad.
You did say the rubber brake hoses were replaced too. Are you sure they are not swelling when the brakes are applied due to a bad hose?
Because the system is sealed, like you I would have gone to the mastercylender. If nothing is leaking, the only thing left is the p-valve.
Mar 19, 2009 at 3:11 PM
JCHEDLEY
Thank you, I guess I will go ahead and change the proportioning valve. Jim
Mar 19, 2009 at 10:13 PM
  • 110,240 POSTS
Let me know if it works.
Mar 20, 2009 at 3:17 AM
