turn signal
JEEP CHEROKEE
BONZOCARR
i have a 2003 jeep grand cherokee, 6 cyl., 55000 miles, and i'm having trouble with my driverside turn signal. it works some times, but most of the time there is no indicator on the dash and no blinker front or back with the signal on. passenger side works fine, so i don't think it's the flasher, and if there was a bulb out then dash indicator would flash rapidly, but it doesn't. what should i check.
Jan 28, 2007 at 4:23 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
Check the bulb. IT has 2 filiments and may prevent the quick flashing you would expect.
Jan 28, 2007 at 7:01 PM
