1993 Jeep Grand Cherokee Scraping Noise
CHEROKEE208
I have a 93 jeep grand cherokee laredo inline 6 with 123570 miles. Yesterday I noticed a scraping sound from what sounded like my front drivers side tire. I inspected underneath both drivers side tires for something caught or being dragged, but found nothing. The sound increases with speed, and so far I have been unable to figure out what is causing it. I would like to know if its something I can fix myself or if taking it to a repair shop would be best.
Jul 24, 2007 at 7:12 PM
MERLIN2021
  • 17,250 POSTS
Scraping sounds at the wheel is usually brakes! Pull the tire and look for scoring of the rotor! Inside surface as well as outside! Check pad thickness.
Jul 30, 2007 at 9:10 AM
Suggested Repair
Remove the front driver-side wheel and inspect the brake rotor for scoring on both the inner and outer surfaces. Check brake pad thickness, since a speed-related scraping noise at the wheel is commonly a brake issue.
Conversation Summary
The owner of a 1993 Jeep Grand Cherokee with an inline-six reports a scraping sound from the front driver-side wheel that increases with speed. An inspection found nothing caught or dragging underneath. The expert says wheel scraping is usually brakes and advises removing the tire to check the rotor for scoring and measure pad thickness.
