Reverse stalling and momentary RPM drops
IBRUZEZ
  • JEEP CHEROKEE
I Have a 1990 Jeep Cherokee Limited with about 125,000 miles. I have two problems: first one occurs while driving, every so often when I hit a ditch in the highway that jolts the car the RPM's will drop for a quick second and then return to normal. On my 30 mile commute it will occur many times but not every time.
The second issue started all of the sudden, when I try to go into reverse the car will buck and kick erratically. Initially it would stay running but now it has progressed and will stall once shifted into reverse.
Any ideas would be greatly appreciated.
Monday, November 6th, 2006 AT 7:55 AM
IBRUZEZ
The more I thought about it I felt these two problems were connected. It must be a broken wire because when I went into reverse the engine torques the opposite way. I traced it down to a severerlly chaffed crankshoft position sensor.
All problems solved.
Thursday, November 9th, 2006 AT 9:43 PM
