Please help!
JEEP CHEROKEE
JASON BARNES
1999 Jeep Cherokee Sport 6cyl. 4x4. I just wired a stereo amp. to my battery. I changed the battery terminal to an after market type required for the install. The engine tries to turn over, but wont until I give it gas. It takes a few seconds of gas peddle before it will stay running. I checked the terminal connections, and they are solid. Again, the amp wires are run but nothing is connected on the other end. It starts only with a jump now and with the gas modulation. What is it?
Feb 1, 2007 at 7:41 PM
KNIGHTRIDERKITT2000
  • 93 POSTS
can you reinstall old connector, if so try it and see if you still have the same problem.
Feb 2, 2007 at 5:28 AM
