1998 Jeep Grand Cherokee Humming Noise
DRAINER0403
[b:c04b4c5474] :x [color=black:c04b4c5474][/color:c04b4c5474]I have a 1998 Jeep Grand Cherokee 5.9 limited with 160,000 miles, the problem is i have been hearing a humming noise coming from the right front side of the engine. I have had a new axle, and front and back wheel bearings replaced. What could this possibly be. I would appreciate it if some one could answer this question.[/b:c04b4c5474]
Dec 12, 2006 at 11:15 AM
BOOTDOG
  • 665 POSTS
have u checked the tires? tires can make a humming noise also. look to see if the tires are making the noise. look for cupping and uneven wear, which would be caused be the alignment or shocks. hope this info helps :)
Dec 13, 2006 at 9:05 AM
Suggested Repair
Inspect the tires for cupping and uneven wear, which can cause a humming noise and may result from alignment issues or worn shocks.
Conversation Summary
The owner of a 1998 Jeep Grand Cherokee reports a humming noise from the right front of the engine after replacing the axle and front and rear wheel bearings. An expert suggests checking the tires for cupping and uneven wear, which can hum and may be caused by alignment or shocks.
