2004 Jeep Cherokee depressing brake pedal & no rear bra
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
LITTLEJOHN
when the headlights are not running on my vehicle & the brake pedal is depressed both rear brake lights will illuminate - if the headlights are on & you depress the brake pedal only the drivers side rear brake light will illuminate, while the passenger side brake light will go completely out
Jan 6, 2008 at 7:07 AM
BMRFIXIT
  • 19,053 POSTS
[quote:51958a7c5b="littlejohn"]Electrical problem
2004 Jeep Cherokee 4 cyl Two Wheel Drive Automatic 65000 miles
when the headlights are not running on my vehicle & the brake pedal is depressed both rear brake lights will illuminate - if the headlights are on & you depress the brake pedal only the drivers side rear brake light will illuminate, while the passenger side brake light will go completely out[/quote:51958a7c5b]
ground wire
check it
also make sure you have the correct bulb and installed
Jan 6, 2008 at 8:51 AM
