2002 Jeep Cherokee Location of Throttle Body and Idle Air C
2002 JEEP CHEROKEE
MHERRON90
Electrical problem
2002 Jeep Cherokee V8 Two Wheel Drive Automatic
Is there anyone out there that can help me find the location of the Throttle Body and the Idle Air Control Valve? Its a 2002 Jeep Grand Cherokee Limited.
Mar 15, 2010 at 11:51 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile. A manual would really be your best friend NOW and LATER.
Pretend you are an air molecule, go thru the air cleaner, down the hose, and when you start hitting aluminum,
YOU HAVE JUST ENTERED THE THROTTLE BODY, If the throttle plate is closed,(idle) the AIC is the next device you would pass by (or be routed thru it at idle)
AIC is a bypass of the throttle butterfly....it allows enough air to slip thru (bypass--the throttle plate) the computer controls AIC to keep idle right. LOOK for device w/ wires, and sorta a motor made to it.
MAKE SENSE? please respond if you need more help, I try, me CJ kinda guy!
Love, Turddog
Mar 15, 2010 at 2:23 PM
