2002 Jeep Cherokee Air conditioning air flow stops,blower o
12,000 MILES • V8 • 4WD • AUTOMATIC
PHIL SANDERS
The air conditioning air flow reduced to a trickle after taking the Jeepl throught a local car wash. Blower motor works on all speeds,heat and cooling changes occur, very little air flow from upper or lower A/C heater vents. Local Jeep dealer stumped.
May 13, 2009 at 4:39 AM
  • 110,248 POSTS
Check to make sure no vacuum lines are off under the hood. Also, listen for hissing sounds with the engine running that would indicate a vacuum leak. Also, check under the dash for the same. The vents are actuated by vacuum and if you lost it, you may be stuck between settings.
May 17, 2009 at 8:19 AM
