2001 Jeep Cherokee See below
JEEPNUT
  • 2001 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 115,000 MILES
Today I was driving on the highway. I was doing about 70 and the car started to lurch back and forth. I pulled over to the side waited a couple of seconds and then got off the highway. The rest of the way was ok as I did not exceed 50 mph. This has happened once or twice before while I was doing about 45 but not as bad. What could be causing this?
Wednesday, June 3rd, 2009 AT 3:58 PM
  • 109,896 POSTS
HAs the check engine light come on? Have you had the fuel pressure tested?
Saturday, June 6th, 2009 AT 11:42 PM
JEEPNUT
The check engine light has not come on. I have not had the fuel pressure checked.
Sunday, June 7th, 2009 AT 9:25 AM
  • 109,896 POSTS
Usually the check engine lught will indicate a problem with an electrical component, sensor... Since that hasn't happened, start with checking the fuel pressure. Here is a how to:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Sunday, June 7th, 2009 AT 3:48 PM
Related General Content
