2001 Jeep Cherokee Oil gage drops down when idleling or dec
BRITTNEEANNE9
Engine Mechanical problem
2001 Jeep Cherokee V8 Four Wheel Drive Automatic
Once my engine warms up my oil gage goes down when I idle or press on my brakes. When I come to a full stop it drops to zero and my check gages light comes on. The gage goes back to 40 when I press on the accelerater. Today was the first time that it has done this in the 2 1/2 years I have owned it. I went and got my oil changed and was told that my oil was not the problem. Do you have any ideas of what the problem could be? I was told it might be the instrument panel cluster or the oil pressure sensor switch. Is it safe to continue driving the car?
Dec 17, 2009 at 11:26 AM
  • 31,937 POSTS
Hi there, what you need to do is get the engine oil pressure checked with a mechanical gauge, this will give you the actual true reading, if it is ok, i would be checking the sender and gauge next.
Mark (mhpautos)
Dec 17, 2009 at 11:44 AM
