When I Slow Down Or Stop My Oil Gauge Drops To 0. What Could This Be From
Monday, October 20th, 2008 AT 9:31 AM
BUDSBABE
MEMBER
0 POST
SPONSORED LINKS
Monday, October 20th, 2008 AT 9:32 AM
LONGDAYAHEAD
MEMBER
You might need a new oil pressure sending unit.
Wednesday, November 12th, 2008 AT 8:36 PM
JNOVACK
MECHANIC
The easyest and cheepest is change the oil sending unit and if it still does it then you will need to change the oil pump oil pressure should be 37-75 psi
Wednesday, November 12th, 2008 AT 8:47 PM
STUPPERKID
MEMBER
I did that and still get it. More than likely is the oil pump. Get the pressure checked via an authorized repair center, saves you the cost of the sending unit that runs about 30-50 dollars and replacement of the oil pump that runs about 600 or more
