2001 Jeep Cherokee Jeep idles rough and gas mileage down to
2001 JEEP CHEROKEE
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEEPER2001
My jeep runs good until warm and is shut off. Upon restart it starts idling rough. My gas mileage went from 20 mpg to 15 mpg. It had a recent tune up and the check engine light said cyl 3 misfire, so i changed the injector, didnt fix the issue. Ever since the gas mileage went down the rpm's are 300 higher at 55 miles an hour. Any thoughts would be appreciated, o2 sensors havent been replaced and catalytic converter is stock. Thanks
Feb 25, 2009 at 9:33 AM
  • 110,240 POSTS
Has the #3 misfire been repaired? Have you checked to make sure the plug wire isn't shorting against the engine? As far as the catylatic converter, listen to make sure you don't hear a hissing coming from the exhaust or ratteling that would indicate a converter problem. Also, a bad O2 sensor can cause the poor MPG. You may want to have that checked too. Has the ck engine light come back on?
Feb 26, 2009 at 10:33 AM
JEEPER2001
The check engine light went off itself and hasnt been back on, prior to fixing the number three injector. The jeep doesnt have spark plug wires is has a spark rail where the boots are directly hooked to the plugs. The o2 sensors havent been replaced yet and the jeep has 98000 miles. There are 3 O2 sensors. As far as the converter, the exhaust system has a wierd rattle when its first started which vibrates the floor board under my foot, it almost feels like its restricted. I have access to a scanner which will show me the ranges that the sensors are in, if I start the engine and check the O2 sensor ranges they should flucuate if I rev it up, is that correct? Thanks
Tony
Feb 28, 2009 at 1:33 AM
  • 110,240 POSTS
Yes, the O2 sensors will. I wonder if the insides of the cat are loose and blocking the exhaust. Also, are the boots on the spark rail good?
Feb 28, 2009 at 5:16 AM
