2000 Jeep Cherokee Starter
HANKHENRY
  • 2000 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 139,000 MILES
My 2000 Jeep Cherokee seemed to have a battery problem. It turned over very slowly then fired and ran normally. I assume that the battery was weak and replaced the battery have good voltage. Now it will not turn over at all. Could the problem have been the starter all along?
Monday, December 21st, 2009 AT 1:13 PM
  • 109,913 POSTS
IT could be the starter or other problems. What I need you to check is this. Have a helper turn the key to the start position while you check for power to the smaller wire on the starter. It should have 12+ volts. Let me know what you find.
Wednesday, December 23rd, 2009 AT 1:01 PM
HANKHENRY
Thanks Joe --The starter had a broken wire from the selniod to the starter motor. I replace the starter and all is fine. Thanks for you reply
Tuesday, December 29th, 2009 AT 6:32 AM
