The cooling fan will not go off even after the engine is turned off. HELP
Sunday, December 6th, 2009 AT 7:11 PM
BLACKOP555
MECHANIC
It shoudl run for a little bit after engine is off. Does it turn off eventually or no? Take off the cooling fan relay and measure on the inlet power from the coolign switch and see if your getting voltage if you are the switch could be bad. If nothing and the relay when pulled kills the fan then the relay is sticking.
