I think the water pump is leaking but I am not sure.
Sunday, July 5th, 2009 AT 3:10 PM
BMRFIXIT
MECHANIC
Coolant pressure test will help in pin pointing the leak
check if its leaking a the lower radiator hose after engine been running and hot
shut it of and check if coolant coming down from top of the lower radiator hose
