2000 Jeep Cherokee check engine light
COMERCIALAUTOSERVICE
  • 2000 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 120,000 MILES
HI WE HAVE A GRAND CHEROKEE LAREDO 2000 6 CYLINDER THE CHECK ENGINE LIGHT ON
THE CODE IS P1899
SAID PARK NEUTRAL SWITCH FAILURE
WE LIKE KNOW WHERE IS THE LOCOTED FOR THIS PART AND HOW I CAN DO FOR CHANGE
THX
Friday, March 26th, 2010 AT 11:21 AM
MERLIN2021
  • 17,250 POSTS
PARK/NEUTRAL POSITION SWITCH (30RH & 32RH) Removal & Installation 1. Raise and support vehicle. Place drain pan under Park/Neutral Position (PNP) switch located near manual shift lever on transmission. See Fig. 7 . Disconnect harness connector. Unscrew PNP switch from transmission case. 2. To install, apply parking brake. Ensure gearshift lever is in Park or Neutral. Ensure operating levers in transmission are centered in PNP switch opening on transmission case. 3. Using NEW seal, install PNP switch. Tighten switch to specification. See TORQUE SPECIFICATIONS . Reinstall harness connector. Adjust transmission fluid level with appropriate ATF. See CHECKING FLUID LEVELS under LUBRICATION.
https://www.2carpros.com/forum/automotive_pictures/62217_Noname_5.jpg
Tighten to 25 ft lbs
Friday, March 26th, 2010 AT 1:42 PM
