2000 Jeep Cherokee
JOHN JACKSON1
  • 2000 JEEP CHEROKEE
Electrical problem
2000 Jeep Cherokee Two Wheel Drive Automatic 213000 miles
i have a jeep cherokee and I thought it was out of gas because the gas gauge did not register.
It does not star tI put a gallon of gas in it and it does not register and do not start
Thursday, September 10th, 2009 AT 12:05 PM
JDL
  • 16,098 POSTS
Welcome to the site, are you saying it cranks good but won't start? If so, have a helper crank it, while you check for spark at the plugs, if you have spark everywhere, use a gage and check fuel pressure.
Thursday, September 10th, 2009 AT 12:22 PM
JOHN JACKSON1
It does not start and no lights on instrument cluster
Thursday, September 10th, 2009 AT 2:49 PM
JDL
  • 16,098 POSTS
For the instrument cluster, check fuse 9--10 amp in the junction block, use a testlite, that circuit goes hot when you turn on the key. Also check fuse 16--15 amp in the power distribution center, that circuit is hot all the time.
Thursday, September 10th, 2009 AT 3:16 PM
