2000 Jeep Cherokee
AMBER1111
  • 2000 JEEP CHEROKEE
I have a 2000 jeep cherokee, 4.0L, automatic, 4x4 and my engine warning light is on what could the problem be?
Friday, August 31st, 2007 AT 1:42 PM
BRUCE HUNT
  • 3,754 POSTS
Will not "crack". What is that? Are you indicating that the car does not turn over? If so, there are several key components to look at: starter, ignition switch, battery, cables.
Wednesday, June 13th, 2007 AT 9:40 AM
CHRIS5656
I meant to type "Crank" sorry.
Yes the car will not turn over. I've looked at all that you said, I've removed, tested or replaced everything in the system according to my chiltons manual excpet the main relay. But I have been having trouble testing the wire to the relays before purchasing a new relay.
Sunday, June 17th, 2007 AT 4:07 AM
Before we start the diagnosis, we need the OBD2 code/s CEL
Saturday, September 1st, 2007 AT 6:47 AM
