1999 Jeep Cherokee Key Won't Turn!
THATONEKAJ
  • 1999 JEEP CHEROKEE
  • 4 CYL
  • MANUAL
  • 127,000 MILES
I drive my car to a gas station from work, car works and starts just fine. I go to restart my car, and the key will not budge anywhere. I can insert it and take it out, but it won't turn on the battery, or anything, will not budge! I also tried every which way to get the key to turn, steering wheel was very stubborn to lock and it did nothing to help. Am completely clueless, any help or advice is very muchly needed! Thanks.
Monday, March 16th, 2009 AT 12:33 AM
Sounds like you might need to have it towed in to get the shift interlock system checked-But 1st check if your brake lights are working if not check the brake fuse and brake switch if okay tme to bring it in.
Monday, March 16th, 2009 AT 12:53 AM
