1999 Jeep Cherokee Engine Stall
JEEP99
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 132,480 MILES
We have replaced the cat converter, 02 sensors, fuel filter and still get stalling or chugging like the motor is going to stall out. It happens after we start the engine and go 1-2 miles then most of the time it will not happen again until we stop and start the motor which it will try to stall out then be OK most of the time.
Thursday, August 14th, 2008 AT 5:21 PM
CLIFF D
I have the same make and year and the same thing happen to my. You need to get a new idle sensor. The car will usaully shut off if your going at low speeds or if your in traffic because the idle sensor is off and the car has problems idling. The part is not that expensive but labor could run you a bit because it's in a hard to reach place
Sunday, October 20th, 2019 AT 4:13 PM
