1999 Jeep Cherokee drain stop up
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICHOLSON630
get capret wet inside car
Nov 4, 2009 at 2:59 PM
  • 110,248 POSTS
Under the hood on the firewall (passanger side) check for a rubber hose pointing down and attached to nothing on one end. Move it around to see if it is plugged at the end. That is where dirt builds up and causes problems.
Let me know what you find.
Nov 5, 2009 at 2:49 AM
CHULEGAARD
  • 35 POSTS
What the other guy said sounds right could also be a heater core gone bad, if the water in the car is coolant, should be able to smell the coolant if so
Dec 9, 2009 at 9:20 AM
