I was having other codes come up, misfires on specific cylinders. Mainly 6 then it cleared and went to cylinder 4. I replaced the coil pack and that did not clear it so I put the old one back on. Then I changed the cam shaft position sensor and the same thing. Reinstalled the old one again. Now I have changed the crank shaft position sensor and it won't stay running. I am getting the 353 code. I tried readjusting the position of the sensor. I had a 351,353, and 1391 codes. Readjusted it in as far as I could and now only have the 353 code. What else can I do?
Jul 15, 2010 at 11:08 AM
