1999 Jeep Cherokee car stalls
JUAN MARINI
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 135,000 MILES
While driving in the road the car will die try to restart will not. But if you wait 10 minuts will restart fine and may run for couple days and then will happen again
Thank You
Thursday, May 21st, 2009 AT 3:52 PM
JDL
  • 16,098 POSTS
Hello, my first thought was, you may be losing the rpm signal intermittently? When the vehicle refuses to restart, have a helper crank it, while you check for spark at the plugs. You can also check for primary voltage at the coil and injectors, dark green wire with orange tracer, engine cranking.
Can you check for trouble codes? Some of the national brand autostores will check codes for free. The codes won't tell you what to replace, just that there might be a problem on that circuit/system.
Thursday, May 21st, 2009 AT 4:14 PM
