1998 Jeep Cherokee Thermostat
1998 JEEP CHEROKEE
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
SACOP
I have a 98 Jeep Grand Cherokee, 4.0 L V6, with 140k miles. My temperature has suddenly started to go over 210 rather quickly, in less than 3 miles normal city driving. I'm thinking thermostat, if so, where is it located on this particular model? Thanks
Mar 10, 2009 at 4:31 AM
THETOOLMAN
  • 123 POSTS
It should be mounted right on the front of the engine on the head.
Mar 10, 2009 at 5:00 PM
WILDCAT8810
it should by located on the engine inside the water pump. that is the pulley in the cneter of the engine.
Mar 11, 2009 at 3:40 AM
BUICKRODGUY88
  • 8 POSTS
Listen to Thetoolman don't listen to wildcat he has no clue i just changed one one and it's on the front of the head where your radiator hose goes into the housing on the passengers side follow that hose and to the top of the engine, your engines head hope this helped.
Mar 11, 2009 at 4:25 PM
WILDCAT8810
it is directly above the water pump. my bad. you will see two hoses going into the housing for it.
Mar 12, 2009 at 8:05 AM
