Ok do you have a digital multi meter? I will need you to test a couple of sensors and see if a couple of them that might cause this are bad. Not all sensors will cause the engine light to come on or set a code, What sould have been done is the shop should have kept the car overnight and ran a running diagnostics to test the coolant temp sensor and the air charge temp sensor to see what they are doing in real time. Anyway we can check those if you have a multi meter. Let me know and we will go from there ok.
SPONSORED LINKS
Thursday, December 4th, 2008 AT 10:42 AM
