Hi there,
A sensor is just a mechanical device, like any other it can and will have a limited life span, there is no set reason for such failures, if the ECU has detected a fault, then it is reading out of parameter and must be replaced, you may have a dirty electrical connection causing this, so maybe check this out first.
Mark (mhpautos)
SPONSORED LINKS
Monday, June 7th, 2010 AT 5:22 PM
