The front brakes on my 1998 Jeep Cherokee keep overheating every so often. The front brake pads were replaced about a month ago. One ten mile trip might be fine but another might leave the discs burned blue. When driving I can sometimes hear the brakes squeak a little even when I am not braking.
I had the master brake cylinder replaced yesterday but the problem persists. Both sides heat up so it could hardly be a caliper fault.
Could it be the servo or the proportioning valve causing the problem. The brake pads I had put in were not OEM but they should not be causing a problem, got them from a reputable motor factor.
The old girl is a 2.5 turbo diesel and she's been a good servant. I'd like to keep her rolling for another while. I'm writing to you from Ireland, found you guys on google. Your help would be greatly appreciated.
Thank you,
Will Buckley.
SPONSORED LINKS
Wednesday, July 30th, 2008 AT 5:01 PM
