1998 Jeep Cherokee hub bearing
1998 JEEP CHEROKEE
TINO54
Suspension problem
1998 Jeep Cherokee V8 Four Wheel Drive Automatic
i've change hub bearing but the clicking noise continue
Jul 28, 2010 at 2:54 PM
RHOHL53
  • 8 POSTS
this noise comes from the brake pads having to much play on the spindle as you release the brake pads they move up and down causing a cliking noise remove the calipers and libricate the guides and spray brake quiet on the back of the pads and try ,if the problem continues then replace both spindles .
Jul 29, 2010 at 5:08 PM
